1 - 4 of 4 Posts
Hi all
Just wondering if anyone has the dimensions for the mounting holes for the CIH flywheel/crank
Need the pcd, hole sizes and the offset angle for the positioning/locator bolt if anyone has them, and any other dimesions come to think of it!!!
Decided to have a crack at machining up my own steel flywheel. I'm maxed out at work so haven't got the time to strip down engines to get accurate measurements.
Also was going to use EN8 or EN24 for the material, does anyone know what the best material to use is??
Thanks
Chris
Anyone know the pdc on the bolt pattern? Cause they are not equally spread cause the flywheel only fits one way.
I think the diameter might be 62, so easy to do the 5 straight onse, the last one I dont know, would love to know the degree of skew of that one.
1 - 4 of 4 Posts
