1. Engines fitted with conventional tappet barrels (all European cars {sic}) should have a rocker to valve stem gap of 0.012 inches. Engines fitted with hydraulic valve lifters (all cars sold in the USA {sic}) have zero 'gap' between the rocker and valve stem.
2. If the engine is in the course of re-assembly, and the cylinder head has just be {sic} refitted, tighten the nuts on the rocker pivot studs so that as the engine is turned, the rocker transmits progressively more movement to the valve. Do not tighten to the point where the rocker ceases to become slack at some point during the rotation of the engine.
3. With a cold engine, and with the conventional tappets {i.e. solid lifters} tighten the pivot nut down until a 0.012 feeler gauge can just move between the rocker and the top of the valve stem. (photo)
4. It is important that the gap is set when the tappet of the valve being adjusted is on the heel of the cam - that is on the opposite side to the peak on the lobe. This is achieved by carrying out the adjustments in the following order:
Valves numbering front to rear
Valves Fully Open - - - - Check and adjust
No. 8 - - - - - - - - - - - - - - - - - No. 1
No. 6 - - - - - - - - - - - - - - - - - No. 3
No. 4 - - - - - - - - - - - - - - - - - No. 5
No. 7 - - - - - - - - - - - - - - - - - No. 2
No. 1 - - - - - - - - - - - - - - - - - No. 8
No. 3 - - - - - - - - - - - - - - - - - No. 6
No. 5 - - - - - - - - - - - - - - - - - No. 4
No. 2 - - - - - - - - - - - - - - - - - No. 7
5. The importance of correct rocker/valve adjustment cannot be overstressed. If the gap is too large, the valves will not open fully and the engine 'breathing' will be constricted. If the gap is too small, the valves and pistons may damage each other, and the engine 'breathing' will deteriorate because during the engine cycle both inlet and exhaust valves will open for longer periods that {sic} intended. Both effects will reduce engine economy and power.
6. On engines fitted in cars sold in the USA, and which use hydraulic valve lifters instead of the conventional tappets, proceed as follows:
7. In the same adjustment order as listed in paragraph 4, screw the pivot nuts down until the rocker-valve stem gap diminishes to zero.
8. Undo the nut until a clearance exists and is detectable and then screw back down one full turn. The adjustment is now complete.
9. On the USA engines it makes no difference whether the engine is hot or cold during adjustment.
