1970 GT
I've noticed that when I apply the brakes the frontend darts to the right, the harder I brake the worse the problem is. I rebuilt the calipers and the master cylinder about 6 months ago and have only recently started driving the car enough to start noticing this issue. I'm guessing that the left caliper is getting less pressure than the right for some reason causing the control problem. It might be my calipers but I'm leaning toward it being a fault in the master cylinder. I already changed both front flex lines and bleed all the brakes.
What do you guys think?
Gregg
Gregg
