· Premium Member
Hey, So far ive figured out all of my electrical problems but the front left turn signal does not work, there is no power to the (+) and the ground is good. all the fuses are fine, any ideas?
· boomerang opeler
try a multi meter on the switch to see if you have power going in and out when its on and if you have power try testing the wire to see if it has broken (see if it has any resistance the multi meter will normaly have a setting that beeps if you have a connection), running a new wire from the flasher relay to the light would then bipass the broken bit
· Member
hey, iam still have no trun signals, but i have power too and form the switch.
and all the way to the flasher, but no click ,new flasher no click, old flasher out other gt that works. still no click, help me!
· Old Opeler
Is there power rigt out to the bulb?
If not then the problem is where the power stops (get an insulation piercing probe with a light bulb) Follow the wires till you find where the is and is not power. Either there is a break in a wire some where OR the ground at the bulb is not working. I that case there should be a voltage drop from the wire in to the bulb to the chasis of the car, measurable with a volt meter.
Something is cutting the electricity off at the pass!
