I'm in the process of changing my control arm bushings, and having trouble putting the leaf spring back in place, is there a few hints on doing this job without a spring compressor?. The one side is in the lower control arm but when I jack up the other side the end bolt for the spring won't line up and if I put that end bolt in I can't jack up the part to bolt the clamp around the leaf spring.
Is it possible to use a come-along , when we try to jack up the lower control arm the whole car begins to come off the jack stands. What can I do?.
Thanks, Mike
Thanks, Mike
