Thanks everybody
:veryhappyI would like to thank everybody who contributed to this thread (especially Kwilford who supplied the photo's of the spring compressor in the first place).
This morning I succesfully finished working on my GT's front suspension according to all the instructions given in this (and some other) thread(s).
I've changed all four ball joints,the bushings of the front leaf spring,the upper control arm bushings, bump stop bushings and the shock absorbers.
Without this tread I would not have managed it.
Shows how usefull this side is!!
And probably without this tread I would not have survived working on the front leave spring (what a strenght is in that spring).
In contrast of most of you I worked on the suspension while it was still mounted on the car letting the spring compressor pulling itself up. It was a little bit of fiddling laying on your back under the raised car, but it worked great.
Had some trouble getting the old lower ball joints out of the A-arm, but with a big hammer, a beam to lay the A-arm on and a lot of brute force (and swearing) I got them out. Tip for refitting a new ball joint: insert it from the right side!!. I was so stupid to refit the ball joint from the wrong side, fortunately I got it back out in one piece.
I also had a lot of trouble getting the new spring eye bushings in. How do you do that, without damaging the new ones?:dunno:
To be certain of my messing about with the car I let everything check by my local garage (one cannot be certain enough about the functioning of the front suspension and steering). They checked everything and found the car in excellent working condition.
So for those who are planning to work on their GT's front suspension: read all threads about this issue and follow their instructions, don't be stubborn trying to find it out yourself: you'll be injured!
And finishing with the legendary words of the Hill Street Blues sergeant: Let's be careful out there!
