No secrets about springs really. We all know the transverse leaf sucks.....
Okay, seriously now, there have been a few ways to modify the transverse springs. There's the lowering block method (placed above the spring, bolted to the crossmember), but this method binds the spring more than stock. There's the aftermarket 2-leaf steel spring alternative....they ride a bit rough but there's a lot less of an arch, so they actually don't bind as much as a stock spring. There's my old fiberglass leaf spring I developed for racing years ago, which doesn't bind and only weighs 6.5 lbs, but costs a few bucks $$$. There's another method I did for my Kadett, which required a lot of labor to cut the eyelets OFF the spring, and fabricate a center-locating device for the spring, and also fabricated plates for the underside of the a-arms with HDPE friction blocks for a smoother ride and no binding. And of course the 'infamous' shackle system, which I first tried about 10 years ago. It works, and it's cheap. Wayne Torman's GT has these installed.
A noteworthy item worth mentioning is that chrome plating suspension parts can be very dangerous on cars that are regularly street driven (not an issue for show cars really). I have numerous friends in the plating industry, and they all warn me never to chrome plate suspension parts, as the process of chrome plating introduces 'hydrogen embrittlement' to the base metal, which GREATLY intensifies the possibility of the part cracking and failing. In fact the SCCA (Sports Car Club of America) strictly forbids chrome-plated structural components...only nickel plating is allowed (nickel is more yellow in color than chrome's silver/blue color). Just a warning.....
I suspect your a-arms are peeling chrome because of the flexing going on there. Remember how easy I said they bent?
Spring shackle installed on a GT.....
