· Member
I need to replace the Fuel Line from the Fuel Pump to the carb... a PO routed it OVER the valve cover. I have Vapor Lock problems ALL THE TIME. Also going to replace the Metal can filter with a plastic one.
Question: When I remove the fuel line from the exit of the Fuel Pump, will the gas drain from the tank? I am assuming not...
Thanks, Mark
· Super Moderator
Thanks, Mark
You will have some seepage as it is below tank level. Just put a short piece of hose on the nipple with a shorty screw driver stuck in the end to block it while you're forming the new fuel line to the carb. Get a length of 1/4" split plastic wire loom to put around the metal fuel line so it doesn't absorb as much underhood heat. This will stop the vapor lock problem.
· Member
Just gushing out
When I removed the line from the Fuel Pump outlet, gas just gushed out, like no tomorrow. Would this indicate a problem in my Fuel Pump? It is the stock mechanical one. I was assuming from the prior post that minimal gas would flow from the outlet.
Please advise.... thnx.... Mark
· Über Moderator
The fuel pump is lower than the gas tank, so it WILL just flow and flow and flow...
I think Otto was suggesting that as soon as you remove the line, have a piece of rubber hose with one end plugged ready to slip over the pump outlet nozzle. Or, just take a pair of vice grips and GENTLY squeeze the rubber line at the pump inlet flat, and that will block the flow as well.
· Member
OK. Well, since I had to replace the entire line from the pump outlet all the way to the carb, I guess what happened was supposed to. I got a length of line on pretty quick that had a plug already fixed in it, but there sure was a lot of gas spilled during that time.
Well with that and a Pertronix installed today, not a bad day.
Thanks, Mark
