I got a question. my 69 gt is not getting enough fuel from the mechanical
pump. I would like to put in an electric fuel pump. the question is what
pressure pump should I install? this is what I would like to use, just don't
know which one, these are from jcwhintey.com
ELECTRIC FUEL PUMPS
a.. Replace or bypass malfunctioning original
b.. Prevent hot-weather vapor lock; ensure easier
cold-weather starts
c.. Work with all fuels and additives
Our smallest pump-3"H x 2-1/2"W x 3"L, weighs just 18
oz. Mount easily in tight spots-no need to remove old pump in most
instances. Not for vehicles with fuel or throttle body injection, nor marine
engines. Can also be used as utility pump for industrial and farm machines.
Includes hardware and instructions. Choose the pressure/delivery capacity
best suited to your needs.
Click product SKU for more detailed information
Item Description Unit SKU# Price Qty. Order
12-volt Electric Fuel Pump, 1-1/2 to 3-1/2 psi, 25 GPH
Deliver Capacity Kit ZX738895X $41.99
12-volt Electric Fuel Pump, 2-1/2 to 4-1/2 psi, 30 GPH
Delivery Capacity Kit ZX738896N $41.99
12-volt Electric Fuel Pump, 4-1/2 to 6 psi, 35 GPH
Delivery Capacity Kit ZX738897T $41.99
12-volt Electric Fuel Pump, 7 to 9 psi, 45 GPH Delivery
Capacity
thanx
ELECTRIC FUEL PUMPS
cold-weather starts
Capacity
thanx
