Howdy all!
As promised, this thread is dedicated to the installation of a Geo Metro mastercylinder onto the existing Opel booster. We will cover the installation in 4-steps and should answer all of the questions out there on this subject.
But before we go into details, let us look at a brief comparison of several mastercylinders and what we can learn from each.
1) The first three pictures show the Geo mastercylinder as you might have seen on different books or web pages. The Geo unit has a 13/16" piston bore, has three M10x1 ports and a low fluid sensor inside the container.
2) The fourth picture is a Honda Civic mastercylinder which also has a 13/16" piston bore and two M10x1 ports. This mastercylinder is from an ABS equiped vehicle and would require a "T" for the front circuit if installed on the Opel booster.
3) The fifth picture is a BMW 325i mastercylinder. This is a multi-bore mastercylinder since the front circuit has a 17mm bore and the rear circuit has a 22mm bore. Also note this unit has one front circuit and two rear circuits which is opposite from the Opel unit.
The first thing we need to look at is the distance from the fluid inlet to the fluid outlet on both front and rear ports:
1) The Geo unit has a long front circuit stroke and a short stroke on the rear.
2) The Honda unit has a short front circuit stroke and a long stroke on the rear.
3) The BMW unit has a long front circuit stroke and a short stroke on the rear.
You might be thinking at this time "why is this important" and "what do I care about this". Well, if you talk to any hydraulics expert about brakes and/or if you visit the Wilwood technical site, you will see that they recomend you use the longer stroke for the circuit that has the largest caliper piston diameter to limit pedal travel. The second point is that this difference in volume helps you balance the braking system without the need of metering and/or balancing adapters most of the time. The Geo mastercylinder is biased at 60/40 which is a good ratio for our application.
There are no mysteries in a brake circuit, they are all based on the same principles and they all work the same way. You press the pedal, fluid goes through the lines and expands a few pistons, clamps or expands liners to a rotating surface and the car stops. I know I left out a few things but the object is for you all to get the general idea.
You are more than welcome to post any comments on this thread as long as you stay within the scope of the work so far posted.
And now, on to the installation....
