Do you know the legnths you ordered? an possibably the part numbers?I ordered new ones from McMaster.
Just was browsing through my order history to try and figure it out. Sorry no way, I ordered way too many bolts for all the applications on the car and it was all done as suggested above, by measuring required length. Just measure what you need. Conversion from inch to metric is 25.4 that is 1" = 25.4mm the 5mm increment available is equal to .197" which is just 10 thou. more than 3/16". HTHDo you know the legnths you ordered? an possibably the part numbers?![]()
I think there are 4 "main" bolts that do all the basic work, and they are the same, one is the one that holds the tube for the auto Opels.need bolt size info for 72 GT, 1.9 L, Auto Transmission,
I need one bolt for the bell housing to engine that bolts in the bracket for the transmission fill pipe.
Are all bell housing bolts the same. If so I will try to find one and use it to get spares.
