Ah, the elusive piston return spring !
Yeah, you can try to reinvent the wheel, but many people before us have tried and the old fashioned round wheel is still the best.
I don't really blame Holley for being a PIA, I'm just some jerk hole trying to do something kooky. They DO have to consider warranty and safety considerations when giving advice. If my sideways Sniper idea DID dribble out fuel at idle it could cause a fire and kill me and if they gave their blessing to it, then they could be held liable. If my 2 injector set up and jury rigging to make it work fried the computer and they told me how to do it, then they would be on the hook to warranty it.
I, too, really liked the charm of the oem solid linkage and I retained it when I had an SSD, but cable throttle works just as good, if not better in some regards, so I'm cool with staying with cable throttle.
I really wanted to go with shorter TB's, there's no need for me to have ones that are DCOE length(118mm). I bought a 118mm length TB so that it would bolt right up to the air box I had for my SSD. I wanted to buy the shortest(30mm), but those have linkage mounting issues. The only other size available from Jenvey is 90mm and that's only 1" shorter than what I already have. My heater box has been removed and the ports on a 2.4 head are about 3/4" higher, which will lift the manifolds higher, so buying 2 new 1" shorter TB's probably wouldn't provide any benefit.
Boy, I'm lucky that I have a good attitude towards failure when I mod. I tried like heck to retain the use of my beloved Steinmetz SSD manifold, but in the end it was just too much trouble and expense with no guarantee that it would actually work any good.
Oh, and I'm NOT going to have any of this stuff chromed. Maybe powdercoated, but I'm done with the chroming. The chroming of manifolds and such caused me all sorts of vacuum leak problems, due to "chroming ridges", that I don't want to go that route anymore.
No, just to one wire to power the injectors per batch, so could be just a single fuse if on the same channel or 2 fuses if running both channels...Microsquirt lost me when their diagram said that I had to add a fuse at every injector
Yes, but you buy the terminal ends and build your own custom great fitting harness.. no butt connectors... like this to your sensors, and you could use a weather tight connector for a main plug (all wires) to the engine for those quick engine swaps at the race track. Lol..and they sent me a crappy harness with no plugs attached to the wires
It's probably a much better system, less tinkering...the Terminator X is much better, just based on that stuff.
With all the mods, upgrades, and customization you have done to your cars, your complaining about crimping a wire terminal ??Those types of terminals are a muthafluffa to crimp correctly.
