As some may already know I've been involved in building air conditioning kits for the Opel GT for some time now. We completely make the consoles now in house, with the rear deck riser and all. My first bolt-on attempt at doing one in a GT involved an expensive serpentine belt system with custom pulleys and custom brackets. It was too costly, and proved that it wasn't right for the market.
The following are hurdles that have to be overcome in my opinion to have an A/C system for the mass market.
1. Bolt on design with little to no modifications that require special tools.
2. Cannot have costly custom one off parts to add money to the product cost, like custom lower hose adapter.
3. Be affordable as an entire package.
4. Have easy to follow instructions and customer support.
5. Be able to work with a bone stock car or slightly modified car (Retain original air cleaner and what not.
So a redesign and re-engineering has lead to a new kit that fits very nicely in a stock GT with only minimum holes that need to be drilled to install. Will clear a group 26R battery to retain battery up front as designed without removing anything. Stock air cleaner can be used, the large 9" booster clears, use of original style fan and shroud as well.
I'm in the final stages of writing the installation manual, and Bill of Material for production. Each kit will be test fit to ensure that the engine parts will line up correctly before ever leaving to help speed up installation as well. The kit includes the center console (all new with controls and vents), the rear risers and shelf ledge, hoses pre-fabricated and crimped, drier, evaporator, condenser, compressor, bracket, pulleys, 7 blade fan with spacer, belts, and adapters. An experienced a/c installation shop could possibly have it running in one day. No hose adapter needed, no clearance issues, no removal of factory air cleaner bracket, no devaluing of the car due to hacking the engine bay for installation. Installation manual will provide exact size patterns, multiple pictures and information to ease in the job.
Kit cost $2550.00 for entire package, with a lead time of about 3-5 weeks on each kit. If I can get several pre-orders, this lead time will be possibly even quicker.
I will only sell the kit as whole, the parts and information is not for sale to do it yourself.
Contact me at [email protected] for more questions or to get a preorder setup.
