1 - 4 of 4 Posts
Hello Newbie here.....
How do you decipher a Opel block number? I have a 1970 GT with a 1.9, however some one mentioned to me that having a * makes a difference in the rarity of the car? I am a Pontiac person and know very little about the GT's.
thanks
436109
Opels aren’t ‘numbers matching’ cars. The best you can really do is get the date code correct.
The block depicted in your photos is a 1.9E, which indicates it came from a 1975 Manta or Ascona with EFI and low compression pistons.
A 1970 GT should have a 1.9S block with flat-top pistons.
The year of manufacture should be in a raised oval-shaped boss just below the starter.
436110
Reactions: Commodåren
Thank you for the information. not sure if that makes the engine a boat anchor or something some one can use for another project. unfortunately the car is rusted out from the front to the rear end.
In Europe the * is an identification mark for engines built from -75 when they lowered the lead content in the gas in Germany. If your 19E would have been from a European car, it would have had a105hp DIN power rating, a solid cam and a 9,5:1 static compression ratio with flat top pistons.
1 - 4 of 4 Posts
