1 - 7 of 7 Posts
Permanent and easy method of fixing broken plastic gauge mounting post in GT dash:
Otto, I did the same to mine on one of the speedo posts. I also took a 1" wide x 2" mending plate and cut it to fit between the speedo and tach, drilled new holes, mounted it on the original posts, and it helps reinforce that small area between the speedo and tach that tends to crack. Jarrell
Screw vs. glue
tomking said:
Good idea Otto. I just glue mine back together if I have the piece. If not, then your trick.
Haven't found gluing them back together to be a permanent fix, regardless of glue used. That's just my experience though.
Pathologic Opeler
nice art
nice art otto.
I have used dry wall screws, it worked
opeldean said:
nice art otto.
Done entirely in 'MS-Paint' . . .
1 - 7 of 7 Posts
