That's exactly what I was thinking.Stock weight is about 2100 lbs. The engine and trans weigh around 350lbs. So a Gt with no power train gets you very close to your 1700 weigh goal.
Weight : | 1785 lbs | 809.662 kg |
Is that dry weight?I looked for my list of vehicle weights by year that I made in the late 70's but couldn't find it, I have it some where. lol I believe that the '69 was just under 1700, something like 1689 lbs and the weights went up to about 2100 lbs. I did look up on-line the weight given for a '70 GT in specifications was:
My guess is the weights I have for are for a basic model. When I find my list, I will post the weights but please don't hold your breathe.
Weight : 1785 lbs | 809.662 kg
Sorry I don't know and the list I made was more than forty years ago and my comment is based on a month or two old recollection. Just guessing about the weight difference but maybe the '69 was calculated with a 1.1L engine and since I had one and swapped it out for a 1.9, the weight difference between the '69 and the '70 could be there.Is that dry weight?
That sounds correct for a 1.1 GT. I remember them weighing just about 1800 lbs, and the 1.9 weighing about 2080.I looked for my list of vehicle weights by year that I made in the late 70's but couldn't find it, I have it some where. lol I believe that the '69 was just under 1700, something like 1689 lbs and the weights went up to about 2100 lbs. I did look up on-line the weight given for a '70 GT in specifications was:
You've got both rollbars in there too, don't you?I weighed my Opel GT last time I took it to the drag strip. I have AC so I expected to be around 2100, but it was actually 2036lbs.
No roll bars (or roll cage), but I have added front and rear anti-sway bar if that’s what you mean. I also have a few lbs of other extras like sheet metal and spare parts.You've got both rollbars in there too, don't you?
... blink...No roll bars (or roll cage), but I have added front and rear anti-sway bar if that’s what you mean.
You can breathe now. LOL For what it's worth this is the info I found but i don't know the year I compiled it.I looked for my list of vehicle weights by year that I made in the late 70's but couldn't find it, I have it some where. lol I believe that the '69 was just under 1700, something like 1689 lbs and the weights went up to about 2100 lbs. I did look up on-line the weight given for a '70 GT in specifications was:
