1 - 4 of 4 Posts
I just bought an early 1972 GT. It was actually built 9/71.
The driver's side interior door panel is temporarily removed because a previous owner thought that the window regulator needed to be replaced. A window regulator from a 1971 GT came with the car with cable, etc.
Does anyone know where I could get some tips on properly installing and adjusting this regulator? I'm sure it's not easy. It may even be a rather mind-numbing experience. I know bolting on the clutch bell housing is no picnic. I had to do that with another GT that I owned previously. I think that I may even have invented some new and colorful words while going through the process.
Thanks,
Brett
Brett;
The whole procedure is covered in the factory service manual. I recently replaced the broken cable in mine. Got the cable from a local hardware store. Used the original mechanism, but, put a new cable on it. Used the directions in the factory service manual to wind up the cable and installed it. Total cost of repair? $1.75
Gene
I replaced a whole door on my GT, which included the windows/crank/handle/latch
It's a PITA to get the cables lines up properly in the grooves on the crank, but it's not too difficult. I mean, I have only moderate skill in mechanics, and I was able to just figure it out by looking at it. You shouldn't have any problems. I had my father helping me, and in all, it took us about an hour for the whole door...so figure 30 minutes for the window...
The FrankenOpel came from the PO with the window down, the door panel off, and the cable looking like a bird's nest in the door bottom. After about 4 hours with no repair manual for a guide, it would roll up and down OK. The giude on the vertical track is sloppy, though, and makes the final few inches difficult to wind up. I believe OGTS rebuilds side windows back to factory specs for US$40 . I am considering some sort of power conversion. . .
Bill and the FrankenOpel
Windows are critical with no AC in AZ!
1 - 4 of 4 Posts
