Better in the sense they resist wear with unleaded fuel...yes.
But worse in the sense the heads crack like crazy. There was already a flaw in Opel's design. The heads have two exhaust ports side-by-side. They happen to be the best flowing exhaust ports in the head. And the intake ports happen to be deficient. So, there is a lot of overscavenging going on, and those center ports tend to run 200-250 degrees hotter EGT's than the other exhaust ports (proven on a dyno, we see 1400-1500 degree temps from these ports on a regular basis!)
To make matters even worse, there's NO WATER between those exhaust ports, nor even an intake port between with a cool intake air/fuel charge to help even-out the temps. Every other exhaust port is surrounded by water on one side and an intake port on the other. Oh, and when they changed the casting design sometime in 1972 to the 12-bolt style, they also changed the cast iron too. It's more brittle. The exhaust seats are VERY brittle. So it's a recipe for disaster. I'd guess that 80-90% of the late 1972-1975 heads cracked.
I prefer 1971-mid 1972 heads. They have 4 cam bearings still, unhardened seats (I add the hardened seats), and thicker ports with a more ductile material.
