i take it that any one who has to ask where to get large quantitys of media is thinking of home blasting
if so unless you have the mother of all home compressors then you will find that it is cheaper and simpler to use a fine grit or a husk medium (walnut/coconut husk) the speeds in a home unit when used properly just dont get up enough heat to worry about
yes they will if you are trying to do a stubborn bit but just let it cool and go back
you dont have to strip it all in 1 pass
and remember to keep an angle of attack so the media does not cut in
if you want a smooth finish a husk medium will do it just fine
just dont stop in 1 place as that will heat it up
also think of how to recover the media as it all cost money
when doing a full car then large sheets of polypropylene sheets are good if you make a frame and cover all the car [ double under the car is better for pick up
think of how you are going to do it
a small gun with a pot will take till next christmas
(and can i be the first to wish you all a merry christmas for 2005
but if you take the pot of you can run a hose straght into the bag of medium
and a white disposable bunny suit from a paint shop supply place is a must as the media will get every where and you just dont want to be wiping your butt with that stuff in it
