I pulled my passenger side headlight rotator and disassembled it as per KWilford's advice in another thread. I had two of the three cog bolts drilled out so I could mount the Headlight bucket solidly.
Here is my current issue.
The headlight will latch closed, but will not open. I removed the rotator again to work it manually. It will work on the side that is used when the headlight is open, but it will not release from the closed position.
Any suggestions on what I should be looking for or modifications. I don't know if the gear that pushes the release mechanism is worn to a point that will not release correctly or what.
