well since i'm nearing the completion of my engine rebuild, i figured it was time to fix the steering colum and headlights before i start driving the car again. i'm sure everybody knows there is supposed to be a inspection panel in the innerwheel wells, to get to the back of the headlight revolving mechanisms right? well a PO had cut part of it out and replaced it, maybe rust...? anyway there was no longer an inspection panel there and he just cut 3 cuts in the shape of a "C" and all 3 cuts were 90 degrees to each other, so one more cut would be a perfect square, so you would bend the piece of sheetmetal back that now forms the inner fender to get behind the mechanism. well there is a plate/bracket type of thing that holds the revolving mechanism up, it is attatched to the body inbetween where the hood goes, and the headlight bucket cut outs are, and the other end of this plate/bracket has 2 bolt holes and bolts up to the inner wheel well. well my plate/bracket was extremely rusty and not having the extra 2 bolts at the bottom that should attatch it to the inner fender, it finally gave out allowing the buckets to bind. so a little time with "C" clamps, prybars, and a wire welder fixed things up ALOT!!! once i got the buckets all adjusted right after putting them back, they work better than they used to before they broke and they dont occasionally hang up anymore. i would like to thank RITTER for all the help, info, and ideas....helped me to understand the revolving headlights alot better than i thought i knew them. and RICH, maybe this is what happened to your GT? if not it must be one of the many things RITTER mentioned. thanks again
