Headliner Installation Tips
OK, I KNOW I have read a posting somewhere that gave really good directions on how to do this properly. I have this task to do myself, and I could have sworn I even printed it out, but now I can't find it. I have about the same problem with disassembling most of my GT over the past 15 years; how does it all go back together, and where ARE all the pieces?
I think it said to take all the windows out first if possible, which describes my car. All the painting should probably be done first, and then the headliner glued to the painted surface.
Attach the window "A" and "B" pillar vinyl covering first, and attach the vinyl with contact cement and lots of those little spring paper clips.Then it said to start at the front of the headliner and glue the front edge over the lip of the window "frame", with more glue and clips. Work backwards, smoothing it out by stretching it over the edges. Finish at the back window, and then the bottom of the "C" pillars. Buy a couple of boxes of those spring clips, because you will need them all.
When the glue dries, remove the clips, trim any excess vinyl, and it's time to reinstall the windows.
Any other suggestions, or does anyone know where the "proper" instructions are?
By the way, if you just found this forum, have you been looking in on the classicopel board, at http://groups.yahoo.com/group/classicopels ?
