I just got my 72 GT running (still needs work) and not driving it yet.
Keep in mind that this car has not been driven since 89......
Basically I have no brake pressure in front (Disc brakes), and bearly in the rear, but can not stop the car and can bearly stop the car using the emergency brakes.
I have the dual master cylinder; the break fluid did drain out for the rear brakes.
I had a friend pump the brakes and the front disc brakes did not move and no fluid came out the bleeder. Checking the rear right, only the left piston is moving (fluid flowing ok and was able to bleed).
I do understand I have to first make sure that there is no air in the master cylinder.
1) How do you properly bleed the master cyclinder and remove any air and can I do this myself without a assistance.
Does this sound like I need to replace the whole braking system or How can I get my brakes working so I can use it?
