1 - 7 of 7 Posts
I have had some problems with getting my horn to honk. 1972 Opel GT
1st ....the wiring diagrams are different in the service manual
which one is right , color or black and white???
2nd ....I understand that the brown wire in the steering wheel
column attaches to the brass ring...but how?? Need detail
on this one, Duh doesn't compute
Thanks Jennifer
Yes I am not a mechanic, but boy am I having fun playing one
Jennifer
the horn wiring is simple!!!! the brown wire is ground and the other is hot.... the hot wire alyways has power with the key on.... that your 12 volt test light out and connect the clip to the ground on the frame of the car and with the key on touch the probe to the hot wire... if it lights the power side of the circuit is working fine
next clip the alagator clip on the test light to the brown wire at the horns and with the key on touch the probe to the hot wire.... have someone push the horn button.... if the test probe lights all the horn wiring is working correctly and it is time to replace the horns... there about $10 each at the auto parts
if the positive wire is not getting power check the fuses.... if the negative side is not making a ground check the horn button on the steering colum.... its a simple repair
get your headlights going??
Joe Van Wagnen
Good wires
I checked all my wires and they were good. Must be the horns themselves, will try that next. Where did you say I could get them?? Just any auto store? Cuz the auto stores suck around here. Thanks Joe
Jennifer
4ZUA787
horns...
i went to my local pick ur part and stole some horns off a 1980's bmw. they yave that german horn sound to them and were pretty cheap like 7 a piece. they also had these rubber boots over the connectors so that they dont rust when they get wet.
1 - 7 of 7 Posts
