I'm in the middle of rebuilding the Front Suspension. I had most major components cleaned and blasted with glass bead. They cleaned up really nice. I already started the painting process as rust will quickly begin to set in on bare metal.
But now I have some parts that I should not paint like the Lug Studs. Or should I?
And the same goes for al the Nuts and Bolts that I am re-using , I dipped them in a rust removal solution and then wire brushed them and now they look nice an bare. I think Rust will set in pretty quickly if I don't treat these with something. I know for the heads I can paint them with some Rust Encapsulator but what about the shaft and treads.
What can you guys recommend…
