How to fit an IRS unit from an 87 BMW 325 into an Opel GT.
The good news: - You don't have to narrow the axles.
- The bolt pattern is 4 X 100mm, same as stock Opel.
- Many different gear ratios are available, and it’s easy to swap the pumpkin (diffy.). I have a 2:93 and a 4:10 Limited slip.
- There are only three mounting points: two on the moustache bar, and one on the pumpkin.
- IRS, Rear disc brakes, and limited slip.
The not-so-good news:
- There is some fabrication required. The BMW unit is too wide, so the mounting points need to be moved inward. (Alternately, I suppose you could do some kind of voodoo on the rear of the Opel rocker panel)
- The stock BMW springs are too long.
- You’ll have to run a FWD offset rim to compensate for the wider track of the Bimmer if you don’t want fender flares.
- If you want a lower-than-stock ride height, some additional fabrication is required.
- With the lower ride height, you don’t have a heck-of-a-lot of suspension travel. As my project is more of a racecar than a street car, a cushy ride is not a priority for me.
Step one - Get the BMW unit. When I pulled the BMW rear end in the junkyard, I made sure to keep the parking brake cables intact, and even pulled the BMW parking brake handle. First thing to do is drilling these large ugly holes in the moustache bar to move the attachment points inward to line up with the GT's box section (~ 36" Ctr to Ctr). See picture in previous post: http://www.opelgt.com/forums/showthread.php?t=4892
Step two, I took a 3” long piece of 1” dia. schedule 80 pipe. (Why this material? It’s what I had on hand, I’m sure you could use some nice DOM tube or something else) and bored it out so that I could snugly fit a piece of ¾” heater hose inside it. I referenced off the original BMW mounting point to position the 3” piece of pipe before welding (just some flat bar and clamps) Then I hacked off the original mounts.
Step three – Cut off the original spring perches, they’re going to have to move inward slightly (I think it was about 1 ¼” or 1 3/8”) to line up with the Opel. I made new perches out of some 12 gauge plate and 1” schedule 80 pipe (hey, this stuff comes in handy!). Then I capped off the cut ends of the moustache bar with some 12 ga plate. [NOTE – If you want to run coil-overs, I have some thoughts on this in step eight.]
Step Four – On to the Opel! I supported the car on a hoist (you could just as easily use jack stands), and dropped some plumb lines to the floor to and made reference marks of the location of the stock rear end. Then I pulled out the stock rear end and stuck the BMW unit underneath (supported on jack stands). I tried to line up the BMW unit as close as I could to the reference marks from the Opel (while compensating for the different wheel offset). This took a bloody long time. It should be close, but the final alignment will come later, so it doesn’t have to be perfect.
Then I scribed a line on the Opel floor up through the new BMW mounts. Drill a big hole in the Opel floor from underneath. This will be the home of the mount built in step five.
In picture four A, you can see three things:
1 – Cut off the Opel’s spring perch. I made a new one from (yup!) 1” schedule 80 pipe and a 5/8” Bolt (The bolt caps off the pipe and screws into the hole in the Opel body to hold it there for welding)
2 – There’s another piece of…you guessed it, 1” schedule 80 pipe hanging down through the new hole in the Opel’s floor. This hole goes into the box section of the Opel. More info on this mount is in step five.
3 – Oops! I wanted to tuck the moustache bar as high up into the Opel body as possible, so I had to ‘relieve’ the inner rocker panel here.
