1 - 2 of 2 Posts
Just looking for advice on the correct sequence of installation. Seems like the regulator and vertical post need to go in first, loosely. Then install the glass into the felt tracks. Slide it down to the bottom. Then position the glass into the lifting bracket with the nylon spacers, etc. Then install the top horizontal bracket on the inside edge of the door gap.
My question about sequence is because: the passenger side glass is already attached to the vertical post and regulator, and I'm not sure it's possible to fit the whole thing down into the window slot on the door and simultaneously get the window into the felt tracks. Should I separate the glass from the lifter first ?
The glass should be put in separately after the rest of the window system is bolted in its proper place. I believe it goes in pointy end first and you have to make sure that the pointy end is in the window channel and carefully place it into the window holder.
1 - 2 of 2 Posts
