How do you remove the shift knob/shaft on th 1.1L standard shifter? This is the long shifter, not the short console shifter. The upper shaft just spins on the the trans stub and doesn't unscrew, and I can't see any set screws or such. Somebody help!
PrOpeller
Re: How the heck?
If it's like the one for a 1.1L GT, there is a large c-clip around the periphery at the base (might be covered with grease). I believe you need a "snap ring" plier to remove it. However, I managed to remove mine with needle nose pliers.
Re: How the heck?
Ahhh, I figured I was missing the boat somewhere! Now all I have to do is stand on my head to find it.
Thanks!
(Just in case you wanted to know) to remove the stock shift knob I believe that you have to put it in water at a certain temperature. You have to do the same thing to get it back on. It shrinks as it cools and is securely fastened to the shift lever when cool.
Yup, needed to know that and didn't even know I needed to know. Hmmm.."The Joy of Car Repair" by Julia Childs!
