G
Guest
·Guest
The better part of today was spent trying to bleed the brakes on my newly acquired GT. Lets just say that things are not going well. The brakes had been pointed out as being weak before I bought the car. The master cylinder and the vacume line to the boost pump had been replaced by the previous owner. When I recieved the car the brakes were bad. I could stop the car with the brakes but had to down shift to help it out a bit and an emergency stop would get scary fast.
When the pedal was depressed it would go 1/2 to 2/3 of the way down then get hard. The first part of the pedal movement felt choppy. (like a rubber seal or boot rubbing against something) It also felt unassisted so the booster was the first suspect. The check valve was first verified as good. The boost pump had vacume when the valve was removed so I spoke with the guys at OGTS to get an opinion. They felt that the boost pump was good and recomended adjusting the rear acentrics and see if things improved. The adjusters were a bit off but there was still no notable difference in performance. This gets us to this morning. OGTS recomended bleeding the system and putting in new fluid if the brakes didn´t improve. First thing this morning I hit up the local parts place and bought decent fluid and a self bleeding kit as everyone else has to work for a living. The first thing that I started with was to drain the reservoir down so that only a small amount of fluid filled the bottom. I filled it back up with the good stuff then the "self bleeding" kit was installed to the right front caliper and we´re off to the races. I started there because I felt this would get any air traped in the front of the system. I thought that I was allowing air into the system this morning while trying to bleed the brakes by myself, but when I got a neighbor to help in the evening things did not improve. The pedal was described as inconsistant and I got alot of air. Now I need help. Could the air be coming in through the reservoir seal at the master cylinder? Or could the master cylinder need rebuilt? I am at a loss now.
Phil
Phil
