Hassle, you say?...try changing a broken one on a Manta in a gas station (NOT a service station) lot on the way home from work...balljoint broke as I pulled up to the pump. The outer end of the control arm caught on the edge lip of the wheel preventing further catastrophe.
It'll go easy....
I haven't done that but I did have to fix my driveline (rear U-joint) on the side of the road. I used stuff I found on the road and a couple sockets from my socket set to hold things together until I could fix it right.
But MORE of a hassle.
I couldn't find my pickle fork and wasn't sure it was wide enough anyhow so I went through the garage looking for my pittman arm puller. I never bought one.
I ended up going to China Freight and picking up a pittman arm puller and knew it was just barely narrow enough to grab hold of the spindle. Worst case, I would have made a shim to spread the load.
NO, that wasn't the hard part. Don't get me wrong, it was still difficult to grab 1/16" on each side but the stupid upper ball joint was in the way of the lead screw being in line with the lower ball joint.
I had to grind off almost a quarter inch of the lead screw to slip it under the upper ball joint bolt.
BUT IT WORKED!!
(and as soon as I had the pittman arm puller I found my pickle fork. It, indeed, wasn't wide enough)
I have it all apart now. Smart enough to tag everything too, except the bolts. They will all go in Evaporust to soak.
I plan on pressure washing the other components. I'll get a price on media blasting and depending on the price I will either pay to have it done or buy another blast cabinet. I won't be able to buy something big enough for the main crossmember though. We'll see.
Then I'm either going to pay to have the crossmember powder coated or just paint it. I will be powder coating the A-arms and spindles myself. My oven just isn't big enough for the crossmember.
