While checking the jets on a "backup" weber (32/36 DVAG) I discovered that the idle jet "holder" (screw) on the primary is larger than the "holder" on the secondary, and the jets, although numbered the same (#50), they are different in shape and size. See the attached photo. The primary idle jet and holder is on the right and secondary on the left. The primary jet has three holes in it and the diameter of the holder shaft is 8mm, where the secondary has just two holes with a 6mm diameter holder, as do all other the idle jets on my other two carburators -- and the idle jet holders are the same size -- interchangeable -- on my other carburators.
Obviously, a previous owner modified the primary idle jet by enlarging the idle jet orfice to accommodate a larger idle jet. What jet was used ? It didn't come from a 38 DGAS. What performance -- or lack of -- should be expected? (Note: I don't have a running Opel to test it) The other jets were:
Primary: main 140; air 170; idle 50 (modified)
Secondary: main 155; air 160; idle 50
Anyone have any ideas or clues ....??
Thanks ..
Ken
Thanks ..
Ken
