Hey guys, I have a small problem with my idle. I have a recently rebuilt 1.9 CIH that is still being broken in. Has a Weber 32-36 carb, flat top pistons, mild cam upgrade with the OGTS small header. It runs, starts and idles very well EXCEPT after a long drive at highway speeds. It will then just die at stops. Feathering the pedal will keep it running. I have tried multiple different settings as far as idle mixture and speed with no help. I am wondering if the heat from the header could be cooking the intake manifold and causing the problem. Have any of you had this trouble? I am considering either header tape or a heat shield to see if it would help but before spending the time and money I am hoping to hear from the voice of experience.
Any advice?
Any advice?
