I have spent two-16hr days installing a new motor in my GT.
I tried to turn the car over. It wouldn't start.
I moved the distributor all the way counter clockwise, and the car finally started, but it was rapidly backfiring through the carburetor(pop-pop-pop). The backfire is as fast as a loose lifter knock for comparison.
I removed the distributor and repeatedly re stuck it with the same result.
I rechecked that my flywheel, #4 piston @TDC, and cam hole were correctly located.
The engine has a ported head, 2.2l valves, domed pistons, and an Irmscher Sprint-style cam. The vacuum advance is removed, and it's plates have been screwed together as well.
Does anyone have any idea what in the hell I am doing wrong? I made sure the piston/valve clearance was ok before firing it up, so I don't see how I could have bent a valve(but to be sure, I'll be running a compression check tomorrow).
If you have any, and I mean any idea for a solution, I am all ears.
- I set the timing mark with the ball, and this with the cam sprocket hole @ 12:00.
- Then, I moved the distributor slot in the timing cover to look like it should in the manual.
- I stabbed the distributor with the rotor in the #1 firing position, and the slash in the rim of the distributor in line with the slot inside the timing cover.
- The plug wires were placed 1-3-4-2.
