1 - 10 of 10 Posts
Hello Everyone,
I need a replacement ignition lock cylinder (w/key) as well as the cylindrical housing that it fits into (contains the column lock and mounts the ignition switch) for a 1972 GT. Some joker worked mine over with a screwdriver, and it no longer requires a key to unlock. If you have the matching door handle locks, that would be a bonus.
Any leads would be appreciated, and if you have a set, let's deal.
Thanks, Dave S.
Replacement lock cylinder
Hello, I know this is a very old thread, but I figured rather than start a new one, I would try to revive this one.
I have a '71 GT that I am finally getting around to trying to breathe life back into before a tear down and prep for autocross.
The lock cylinder is missing from the column, I do have a key that seems to fit the door, but not work well.
Is their a source anywhere for replacement lock sets? Doors and ignition? I would to change all three if I could.
Thanks,
Ryan
I may have a complete set, if not I definitley have a mismatched set meaning you probably will only need the ignition switch
That would be great, I tested the key in the drivers door, and it sort of worked, not really well though, made me think a complete change may be the best option if possible.
But I will settle for what is possible, maybe I can get fresh blanks and see if a lock smith can get them to work better and match a replacement ignition to the doors if needed.
No, I want to be able to lock it up in the carport while not in use. I don't have an enclosed garage to hide it in at this point.
If I had a secure location for it I would pull the interior lock rods out and call it good.
1 - 10 of 10 Posts
