My car has a pushbutton start crudely installed. Start process has been to turn the key to "run", listen for the fuel pump to hum and depress start button. Car always starts but sometimes take a couple of trys. Suddenly car will not start, and in frustration or just monkey business I held the ignition key at "start" and depressed the starter button at the same time, and, varoom! only to relax the ignition key to run and then the car falters, twist the key back to start (which does not actuate the starter motor.) and car runs fine. To clarify, the car will only run when I hold my ignition switch in the start position, Holding the ignition switch on start does not engage the starter, that has been bypassed by previous owner.
I have replaced the electrical part of the ignition switch. Disconnected the horn, reverse light, and winshield wiper feeds from the fuse block. I belive my wiper circuit is responsible for blowing fuse #1.
Spent a fair amount of time looking at wiring diagrams, and with my head in the footwell today. My next guess would be the "resistor cable transparent" from fuseblock to ignition coil.
Any insight would be greatly appreciated.
By the way, The Fuse block is hanging by zip ties. Almost all underdash wiring looks stock, right to original radio. The wiring is rotten to the core. The good news is the wiring is the worst problem the car has.
Cheers.
Cheers.
