hope
You may not even have to remove the column at all to have a key made. If you car is origional, remove the door locks instead and have keys made from them, they will work in the ignition too. If not, or as a back-up, get the # code off the tumbler set and any good locksmith should be able to make you a key without even seeing your locks. I can't remember off hand how hard it is to get to the # code on a GT ignition, but looking for some #'s is easier then removing the column.
I was able to remove the lock without the key on my GT, but I honestly can't remember enough of how I did it to be able to offer advice. It can be done, though, if necessary somehow.
Good luck!
Stephen
Good luck!
Stephen
