1 - 8 of 8 Posts
Certified Opelholic
I want to make a multi groove pulley setup for the Opel CIH motor.
but I cant find the specs on the multi groove part. I was hoping someone could help me out or point me in the right direction.
this what I have so far
thanks in advance
Davegt27
Certified Opelholic
Discussion Starter #3
multi
thanks but I was looking for some published specs
I have a few Toyota superchargers and a crazy thought came up
why not put a supercharger on an opel CIH motor
the problem is the Opel has an old fashion V-belt
but newer cars like the 1989 MR2 has multi groove setups
i think this is it
http://www.misbelt.com/images/pro/special_timing_belts/microvs.jpg
plus I need a lathe project for this CNC class I am taking
Davegt27
Dave, you're talking about a serpentine belt pulley on the end of a single groove pulley. That would be a neat piece of machine work, and may have a market, also.
I have been Looking!
Some years ago I did some Micro-V pulleys and had the code ... but it has gone now - on an old computer hard disk. :ugh:
The grooves were cut with VBMT tips with 0.4mm nose radius
From memory one groove was drawn out on Master-Cam and replecated the required number of times to produce the complete form. It was an SAE standard.
BTW: Opel CIH motors from 1991-94 (Omegas; Senators and Fronteras) had serpentine belt drives with Micro-V pulleys.
Perhaps your local Gates belt supplier would be able to get you the specs for pulleys suitable for the serpentine belts they supply - if he is real good maybe even the CNC code! Ask for the Toyota Suprcharger belt/pulley specs.
It does have a market but will need to be balanced which is why our serpentine setup did not make it too far out the door. In california there is a company that makes them with or without the V-belt add on. See pics enclosed.
Certified Opelholic
Discussion Starter #7
Thanks guys
I was thinking of making all new pulleys
From memory one groove was drawn out on Master-Cam and replicated the required number of times to produce the complete form. It was an SAE standard.
Perhaps your local Gates belt supplier would be able to get you the specs for pulleys suitable for the serpentine belts they supply - if he is real good maybe even the CNC code! Ask for the Toyota Supercharger belt/pulley specs.
I went buy NAPA and got some of the info and then applied that formula on that link that I posted to come up with the specs
now I just need to figure out how to draw it
Thanks
Davegt27
Specs
Thanks
Davegt27
The 'spec' in that link is not enough to draw pulleys as it is only a partial of the belt itself - you need specs for the pulley grooves.
The pully has grooves that go right down to a radius - not cut off flat like the bottom of the belt. The cut-off leave clearance room for debris etc.\
You also need the angle of the sides - some belts are 40 degrees; others are 37 1/2 degrees and others yet are 37 degrees.
You need to let us know exactly what type of belt you intend to use - what shape/section is it called?
1 - 8 of 8 Posts
