battery tray chop cut for a/c car
This could be a long post, but I'll try to make it as short as possible for a start. There were 2 units installed in the GT, A GM unit and an ARA unit. They differed in where the compressor was mounted and the type of cowling used between the seats. Both had the condensor mounted in front of the radiator which caused the battery tray to be rotated 90 degrees and a hole had to be cut in the belly pan to remove and install the battery. Both had the cooling unit mounted behind the rear seats and a raised shelf was placed over the units. The GM used the rotary compressor mounted above the alternator, the ARA had the compressor mounted low on the right side of the engine and to the water pump. Both had lines running under the car, through the floor and in to the cooling unit and they both had two groove pulleys mounted on the crankshaft. The GM used a vacuum operated microswitch to turn the compressor on and off depending on engine vacuum. Those are the differences I'm aware of, I have/had a GM on my 72 GT, and when working it would throw ice cubes, figuratively speaking out the hole between the seats. It was missing the ducting between the seats and around the brake and gear shift. HTH. For a start.
hey opel guy's
i just pulled the battery out of my 73 gt , reason being last owner
removed A/C condenser. well after removing battery i found it had a tray
spot welded to factory battery tray cross ways. so i removed it ...
pick a part 5.00 $ tray chop cut sheet metal screwed in just like the
ad on tray i removed. well i put condenser in it with new dryer last guy
cross threaded tubing so new tube end too....
after all is said and done now i don't have enough room because
the condenser takes up like 4'' of elbow room. the battery that was
in it is group 26 just like it calls for and it fits just fine in the factory
tray under rusted out ad on tray it also fits like a glove in ad on tray
so back to pick a part for Honda battery tray chop cut build. so i can
put i battery in it, that will make it past the condenser with out removing
the condenser .....is it the norm to pull condenser out to change the
battery??..because that is the only thing that makes sense. other than
down size tray and go with group 51 battery........
