That I can bolt in that is compatible with the stock GT regulator? I'm looking for ar:lmao
und 80 amps
There is a conversion, that uses a stock GM 105 amp alt, with internal regulator, and except for buying an aftermarket lower bracket, which you modify by elongating one of the mounting holes, is a bolt in. I have this conversion on both my Sportwagons, will work on GT's, Kadetts, Mantas, etc. Have had mine on for quite a few years and no problems.That I can bolt in that is compatible with the stock GT regulator? I'm looking for ar:lmaound 80 amps
There is a lot of info on alternator upgrades in this forum: 1A - Starting and Charging SystemThat I can bolt in that is compatible with the stock GT regulator? I'm looking for ar:lmaound 80 amps
There's the cry-sler single pulley that can be converted to be controlled by theis there a GM alternator
That I can bolt in that is compatible with the stock GT regulator? I'm looking for around 80 amps
Do you have a part number? I'll be looking on the Auto Zone website. Can I get o thx:lmao:ne for around $75There is a conversion, that uses a stock GM 105 amp alt, with internal regulator, and except for buying an aftermarket lower bracket, which you modify by elongating one of the mounting holes, is a bolt in. I have this conversion on both my Sportwagons, will work on GT's, Kadetts, Mantas, etc. Have had mine on for quite a few years and no problems.
CS130 Alternator (Gold-Duralast) - Autozone part number DLG1345-6-7Do you have a part number? I'll be looking on the Auto Zone website. Can I get o thx:lmao:ne for around $75
How much is alternator and pigtail cost? ThxCS130 Alternator (Gold-Duralast) - Autozone part number DLG1345-6-7
CS130 Alternator Pigtail (Painless) - Summit Racing part number PRF-30707
Alternator F-bracket (Spectre) - Autozone part number 42273
The CS comes in at ~ .01 scents.How much is alternator and pigtail cost? Thx
I found a couple of duetchmarks under the passenger seat will that be enough?:lmao:The CS comes in at ~ .01 scents.
The piggie tail is a very wallet hammer ~ 999,999,999,999.01 euro.
Fox Body is that a Chrysler?Yepper any fox body has a CS.
