1 - 11 of 11 Posts
Opel gone bad
I added the photo to your post. And did you see the engine swap? It's a Toyota 1900 OHC, with a Weber and 5 speed. Probably not a lot of extra horsepower, but a very clean swap
Keith, that's either a 2tc (1588 cc) or a 3tc (1770 cc)Toyota engine, which is a hemi-headed engine but with the cam in the block, pushrods and all. Very durable piece of equipment though!
4ZUA787
that grill just looks like square tube probally 1/8 wall thickness and probally like 1.5 by 1.5. would probally be easy to do if u had a nice di-acro bender, then jus go get it chromed and desing some way to mount it from the back.
Opel with Toyota engine
Bob are you saying that would not be a 1900 cc Toyota engine?? Or would it be a 20R?
How would the engine in the picture compare to our Opels for power or the ability for performance upgrades? I am only 4 hours from Las Vegas and wouldn't mind seeing this transplant. (Actually I've seen two toyota transplants like this in a little mexican town not far from where I am located. The five speed speed are a bit longer than the Opel)
4ZUA787
well a 20R would be a 2.0 carbureted and a 22RE i believe its called would be a 2.2 FI and ive seen many of those engines and they look way diffrent then this. what is the engine is what id like to no is it a real 1.9 toyota??
I might stand corrected. It is advertised as being a 1900, but who knows.
Which is what came to mind when I saw it. I don't have much experience with Toyota engines, except the 22R that was in my old '82 Celica. It was carburetted, and looked something like the photo. But I sold that to buy an '84 Caravan "Magic Wagon" (wow, was THAT a poor name for a piece of CRAP!) when the first of three daughters showed up
3tc
The '80 Corolla came with the 3tc 1.8L motor, which looked like that. What you can't see well is that it is a cross-flow head, so the exhaust is on the drivers side somewhere.
My '80 Corolla wagon was rock-solid dependable, had a nice 5-speed transmission, and had slightly more performance stock than a stock 1.9L Opel motor. Of course it also had over 200k miles on it, so I'm not sure how a new one would have performed.
An older non-emissions 2TC had 88 hp. The later emissions-style 3TC had 75 hp. Toyota's 20R is in fact 2.2 litres, while the later 22R is a 2.4 litre engine. The older 8RC was a 1.9 litre however, but that was not that common in the US (older Carina models primarily).
Gary said:
If I remember correctly, the 20R was not a hemi so the plugs were on the side of the head.
Correct Gary, the 20R was a SOHC design, plugs facing the driver's side. Still a crossflow head however.
1 - 11 of 11 Posts
