1 - 9 of 9 Posts
· 1000 Post Club
If you are going for a stock restoration of a Manta, Ascona(1900) and Sportwagon then yes, it is a good buy. I don't know if Kadetts used this coil, but if it had a 1.9, then it should work.
I've only seen a couple GT's with this coil. It will work
A lot of people upgrade to a petronix ignition and match it up with a flamethrower coil.
Again, if your Opel currently has this type coil and you are doing a stock restoration, then I'd bid on it.
Jeff
· boomerang opeler
it is if you are doing a 100 point concourse car where everything has to be exact ,but for normal use you can get coils much cheaper that do the job
· Super Moderator
What everyone is trying to say is, that if you want a 100 pt "correct" car, and not worried about performance, then go for it. But, if it's performance you're after, then these are worthless. Get a BOSCH "can" type coil or a Pertronix unit
1 - 9 of 9 Posts
