1 - 12 of 12 Posts
I recently happened onto some NOS Kadett parts. If anyone is interested please email me with what you might be interested in. I know this is vague but I still haven't identified all the little parts bags yet. I have gasket sets for the 1.1's, tranny stuff, and some axle stuff, along with some interior trim pieces but not much. Email me with your requests and I'll look specifically for the items.
LOTS of water pumps! A couple of generators, lots of gen. brackets, and some steering column stuff.
Harold
[email protected]
Sorry for my ignorance but I had to look up what an "A" was, but no everything was later 66 and up with most of it being 69-70. There was quite a bit of 1.1 engine stuff.
Harold
Picture!
If you lay it out and post a picture of it we could sort through - I have a '67 Kadett and would be interested in parts that would fit it - has a 1.1 engine!
Thanks
Hear are a few of the parts that I need help identifying. Some probably aren't even Kadett parts but you still might be able to help me identify them. One of the cables is probably a hood release since it has a T handle, but for what?
Thanks,
Harold
Pictures 2, 3 and 4 are headlight cable, clutch cable and hood release cable for a GT it looks like. The others look Manta ish.
Cables are too short for the applications you mentioned. The T handle one maybe but what you can't see in the picture is that the end isn't adjustable like it is on a GT. I have dealt almost exclusively with GT's and usually can ID those parts unless they are look alikes with slightly different dimensions.
Harold
Need more expert help!
These lenses may or may not be Kadett. The clear lenses are two different styles. The round amber lenses are made to fit on a flat surface. I have a similar lens that is made to mount on an angled surface.
I've added another picture. The third picture has the lens for an angled surface. These lens is for a 66-67 Kadett, P/N 12 26 379. The one on the right is the same as in the second picture.
Thanks,
Harold
Discussion Starter · #10 ·
I believe the first clutch cable with the threaded end is for a 66-67 Kadett and the cable with the eye and e-clip adjustment is for late 67 Kadett's.
Harold
Kadett parts - cables
Thanks,
Harold
Picture 1: 69-70 Kadett, cable, front seat latch - PN 166505
Picture 2: 68-71 Kadett and 69-70 GT, cable, 1.1 clutch - PN 669021
Picture 3: 68-72 Kadett, cable, 1.5/1.9 clutch - PN 669024
Picture 4: 68-72 Kadett, cable, hood latch - PN 1178472
I'll try to figure out the hoses from a numbered picture in a subsequent post.
Discussion Starter · #12 ·
Thanks Otto, I figured if you looked you could confirm what these items are. PROPEL identified one of the valve cover hoses but when I compare it to the book the last digit is off by 1.
I had spotted the seat cables in the illustration catalog this afternoon while I was looking for something else.
Harold
1 - 12 of 12 Posts
