1 - 4 of 4 Posts
Hi All,
I have a question about a new set of racing shocks I got from OGTS. Gil says these are what I need for a lowered GT. They are adjustable racing shocks.
My question is about the adjustment of the shock. On the body of the shock, it indicates a "+" and a "-" direction. I'm assuming this is for the firmness of the shock. I compressed the shock and rotated the shock in the "-" direction. After the shock stopped turning, I was unable to uncompress the shock to reinsert the rubber stopper.
I tried turning the shock all the way in the "+" direction and when I got to the stop, I was able to uncompress the shock. I'm confused.
The only instructions that came with the shocks are little pictograms. No wording whatsoever.
Doesn't "-" mean less firm? If so, then why couldn't I uncompress the shock?
Thanks,
Manny
It does sound backwards. When the shock is at full stiffness the rebound damping will be so stiff it will take a LOT of force to fully extend the shock.
Certified Opelholic
I think the old Koni's are one way adjustable in rebound only.
I just looked at my Red Koni's and I cant even find a plus or minus sign at all.
turning the bottom to the right makes it stiffer to the left softer
don't set them full stiff i flew off the course when i tried that (the car would not turn in)
Davegt27
Davegt27
The yellow Konis have about 2.5 turns from full soft to full stiff. I set mine at 1.5 turns from full soft. And it might be just a tad too stiff for some of the roads around my house. It feels great on a smooth stretch of road. Really feels controlled. But once I get get a couple of bumps, I feel the rear is bouncing off the road. I'll set it at full soft and adjust from there.
Manny
1 - 4 of 4 Posts
