941 - 949 of 949 Posts
Discussion Starter · #941 ·
Too much stuff/crap!
I’ll remember that next time you are looking for spare parts and no one else in New England has them! 😂
Discussion Starter · #944 ·
Well, You don't even give me my parts that you have had for over 10 years, why should expect anything?
I have a pile of your stuff in the basement, come and get it! 😁
Discussion Starter · #945 ·
A prototype part I contracted out. So far it looks like it will work nicely.
I designed them to accept aftermarket o-ring fuel injector bungs. This way I can use the common 14 mm Bosch-style injectors, or the newer 15 mm GM LS-style injectors. I can also install the bungs at various depths to vary injector height from the intake runners.
These of course require a custom fuel rail designed to work with o-ring injectors too. I’ll have to supply that part as well.
Don’t ask me about price and availability at this time, as I don’t know yet.
435126
435127
435128
435129
435130
435131
Discussion Starter · #946 ·
The aforementioned extruded fuel rail, machined to fit the Opel injector spacing pattern.
435132
435133
435134
435135
Reactions: kwschumm
Hopefully you won't have to machine it flat again after the bungs are welded. You could bring the mating surface in pretty easily on a real flat plate with some stickum 180 grit. That looks like a nice part.
