I am looking for a NEW set of HYd lifters. Anyone found a source cheaper than OGTS? Anyone got a set they want to part with?
They're still available from GM here, as they're made in Michigan and shipped to Opel for all the hydraulic-cammed CIH engines.GTJIM said:Try checking your local Buick dealers (before GM closes them down!)
The original GM Part # 5232685 also marked "HL-70"
Come in packs of eight hydraulic lifters for Opel 1.9L motors.
You never know what they might still have.......
Jim, are you sure about that? I know that the the lifter and cam lobe surface gets "mated" as they wear in together, but I thought that a new lifter would get similarly mated so long as the cam lobe isn't compromised (as in partially worn out).GTJIM said:First never put new lifters onto a used cam as they wear out at a horrendous rate due to the wear pattern that has been made on the cam lobes by the old lifters.
It's called "Irish Roulette" , Keith - all the cylinders loaded and hope for a mis-fire.kwilford said:Jim, are you sure about that? I know that the the lifter and cam lobe surface gets "mated" as they wear in together, but I thought that a new lifter would get similarly mated so long as the cam lobe isn't compromised (as in partially worn out).
Any other opinions on this?
these have themsvopel said:Anyone know of a source for NEW solid lifters? OGTS does not have them.
Thanks ... Ken
Anymore news on the above item? Thanks, Jarrellbaz said:http://www.mantaworld.com/opel-manta-tuning/camshafts.php
i was going to try for a group buy for solid lifters but mike(motor mouth )said he thought he could get them cheaper so i left it to him
any movment on them mike?
