Below are some pics of the bracket I had made to hook up the Lokar cable to my SSD Solex.
It's about as direct as I can get it.
The concern I have with it is that the cable has two fairly tight radius turns in it. It takes a lot of force to pull the cable through. It's OK using the foot pedal, but by hand, it is difficult move the linkage at all and I'm concerned about the stress on the arm that pulls the cable down.
When the cable is extended straight it is OK so the bends are the problem.
Should I lubricate the cable in an effort to make it easier and if so, what with? Any of you custom builders have any tricks?
