I finally got around to dropping the front subframe to redo the everything that needs to be done there. But I had a bit of a problem removing one of the bolts.
Unfortunately, when trying to get it to unthread the bushing itself disintegrated.
I was wondering if anyone knew the part number for the "Extension to body shell vibration bush" shown here as Number 4 in the diagram below
434449
OGTS doesn't carry it. And I haven't heard back from Opels Unlimited.
I'm told european sources might be my only hope. But I can't find anything when I search so I'm hoping one of you out there knows the part number.
434450
If you click on the RallyBob quote in Gary's last post in the other poly suspension thread there's a link on where to find the poly bushing you're looking for here in the US
I’ve used Chevy truck leaf spring bushings from Energy Suspension before.
Found @RallyBob 's post for the energy suspension parts. And I'll honestly probably do this. Poly all the things.
I was just curious if anyone had the P/N for the stock rubber bushing.
