1 - 3 of 3 Posts
is there a way of installing a lower ball joint without removing the lower a arm? on my project, one side is removed already but the new one gust doesnt have eniugh room to get in the hole. i tried to remove the a arm but the bolt holdong the leafspring just wont budge.
i thought about grindong some material off of the spring to get theball joint in, but worried if i will loose any strenth there.
· Old Opeler
Rip
Sounds like the bush in the sping eye has worn out and let the spring eye move out far enough to block the access to the lower ball joint.
1 - 3 of 3 Posts
