Hi
I am rebuilding my front end to use adjustable coil overs and I am thinking of making new lower A arms to go with the new upper A arms that I am fabricating..
It would make life easier if I could find some ball joints that bolt on just like the the standard upper ones do.
I have seen the ones on the site that screw on to screw on adaptors but these require the spindles to be reamed out.
Track rod steering arm joints could also be used but again does anyone know any that are the same size as the standard lower joints.
I am also later thinking of using MK2 mx5 rear suspension narrowed to replace the solid axle. I will be using RX8 lsd and shortened half shafts as well.
This has been done recently for a mini and seems ok. Its actually a four wheel drive setup.
Of course there are many diffs that could be used
The standard mini track is 48 inches so its in the correct ballpark.
I think that the subframe would need to be further modified from this point in order for it to fit the opel gt, a square flat box frame into a curved gt underbody, but it is worth investigating for well under 500 bucks.
