1 - 6 of 6 Posts
· Member
The brake system. The master Cylinder is not from a '74, so what year/vehicle did it come from. Also specs on the vacuum booster, calipers, and rotors. How well does the system work/drive now.
Darrin
· Super Moderator
The master cylinder is an *** replacement unit. Fits on the '73-'75 models that originally had the Delco master cylinders. This was the unit that was sold by Beck-Arnley and other aftermarket suppliers when the Delco units were no longer available. Basically it's a Manta B master cylinder. No big advantage, same bore size. In fact, I don't like them personally, they're a bitch to bleed properly, they always seem to trap air.
· Member
I have talked to owner several times. It was for sale on ebay before with no bids. I "bought" the car 3 times. The price went up after we agreed on a sale. The last time I just said no. Kind of sucked, oh well. Good Luck!
DAN
I went to see and drive the Manta last Friday the 18th.
Here's the report:
(I would like to first say I don't own a Manta)
The engine starts and runs smoothly. I was impressed how smooth it was with the dual Webers. The engine is bored 40 over. (1900 motor). The clutch was dragging a bit. It only sounded like it needed to be adjusted, but that was the only noise the car made. No creaks or squeaks from anywhere. The rearend was smooth and silent. Shifted just fine. I didn;t care for the way the gas pedal was setup. This is probaly just a taste thing.... was to hard and sudden for me. But funtioned just fine. The car felt "tight" over all. I had good power. Brakes were good. Sorry, I didn't look at the brakes as to what type they were. I was focused on the rust and overall condition of the car. Although the brakes felt good and responsive. The electrical was ok. The only thing I could see that was wrong was the ignition had an override. But did say the ignition was working now. Nothing real serious.
Rust: There is some rust. The good news is...MOST of it's surface blisters. I took a few pictures but need to have them scanned. The locations are as follows (with a small rating system.. 1=very little/cosmetic - 5=serious, near unrepairable damage.
A little around the driverside door handle. (1)
Bottom of the driver door. (1)
Bottom sill below driver door. (3)
Rear fender, driver side. (1)
Bottom of trunk, below bumper. (4)
Pax side rear fender. (1)
Around battery on driverside. (3)
Overall it isn't bad. He did reveal the reserve price of $1600 but would take $1400. I don't think it would be too hard to repair the rust spots in my opinion. The interior needs a bit of work too. I wouldn't classify the car as mint or great obviously. It needs some TLC, but would be fine if you plan to put a bit of sweat into it. I would say I could be a nice Manta. Especially for only $1400. The engine setup alone is nearly worth that much.
Bob- for a race car it would probably be ok. I didn't see any major hardpoints effected by rust. Virtually all the rust is surface or "body" rust that can be repaired relativly easily.
HTH anyone....
~kyle
1 - 6 of 6 Posts
